i recently bought the MK2 Hercules and noticed ther is no wher t put headphone, do i need a spliiter or nefin, wher can i buy it from etc as i hav a gig on saturday for a friend
geposted Mon 01 Dec 08 @ 4:27 am
Enter your serial in your profile so you can download new update of VDJ for your console.
Also update driver for MK2 from Hercules site.
geposted Mon 01 Dec 08 @ 4:43 am
well i wud but atm im at work so cant! i got it off amazon and there only seems to be one slot, one for the USB t connect t laptop therefore wher do i put my headphones!
geposted Mon 01 Dec 08 @ 5:43 am
There is a 6.3mm socket on the front edge of the MK2, marked HEADPHONES ;-)
geposted Mon 01 Dec 08 @ 5:44 am
There you go ;)
geposted Mon 01 Dec 08 @ 5:50 am
sorry its the other version of the Hercules! just double checked, its the bog standard one for MP3 mixing! ther just one output at the back!
geposted Mon 01 Dec 08 @ 7:23 am
That is Dj Control Mp3, it has no sound card so no connections. You connect everything on computer.
geposted Mon 01 Dec 08 @ 8:35 am
does tht mean then i can use just bog standard ear plug into the socket of my laptop, wnt tht stop the sound of the whole thing?
what can i do, help! i a total beginner and really wanna get started!
geposted Mon 01 Dec 08 @ 8:43 am
If you have 4 channels sound card you can setup VDJ to "Headphones" option, Front speakers output will be the Master Output (the position of the crossfader) and second output for Rear speakers will be preview output and there is where you gonna connect your headphones. Remember to set your sound card in 4 or 5.1 mode.
geposted Mon 01 Dec 08 @ 8:57 am
wil a 5.1 USB sound card do the job, only has 2 outputs for speakers i think and headphones!?
geposted Mon 01 Dec 08 @ 9:19 am
It will do the job, you have the answer in the other topic.
Please do not open multiple topics about same question.
geposted Mon 01 Dec 08 @ 10:29 am
