Hey guys, what mode do you use when using Serato Vinyl? Absolute, Smart or Relative. When I use Serato, it give me a error message that no timecode was found and check connections. I chose noisemap and still nothing. Deck B spins like crazy on my screen with no song on the deck. I am using a Maya44 sound card. Thanks.
Syberman
Syberman
geposted Mon 01 Dec 08 @ 9:49 am
Anyone?
geposted Mon 01 Dec 08 @ 3:43 pm
Absolute. If you have never setup Timecode before here are some settings for the Maya you might try ...
Maya44 Soundcard Setup --
Click on the ASIO Configuration button.
In the first tab with all the channels displayed.
Mute the first 4 for Monitoring the inputs.
Set the INPUT Gains at just below 50% (1/2) at about 40%.
Set the OUTPUT Gains at 100%
In the Timecode Configuration, uncheck the Clear Sound option. Use a pitch sensitivity of about 800-1200 (1200 is default, 800 has been found to provide better resolution). Run the Auto Config for both decks.
Now try your timecode, how do they respond ??
geposted Tue 02 Dec 08 @ 6:24 am
Thanks cstoll, I did what you told me and I still get the error message of "No timecode found." I did the settings as you said with the Maya 44 and time code config. I don't get past 3% on either deck but when I play a song on either deck, it works great! I don't know what's going on.
Syberman
Syberman
geposted Tue 02 Dec 08 @ 1:24 pm
