Hi Guys.
Can anyone tell me can Flac & Mp3's be in the same folder as i have ripped a load of cd's to flac format and want to replace the Mp3's.
Many Thanks
Many Thanks
geposted Mon 01 Dec 08 @ 1:06 pm
They can go in the same folder however your new flac files wont replace the old mp3 files so you will have to manually remove all the duplicate mp3's
geposted Mon 01 Dec 08 @ 1:12 pm
Thanks for your reply and yes i have just found that out It would have been nice just to copy over the new files and replace so i will have to do it the long way round
geposted Mon 01 Dec 08 @ 1:20 pm
The only difference between the two is the file extension but that's enough! it may as well be a totally different name altogether.
geposted Mon 01 Dec 08 @ 1:40 pm
