Hello!!
everytime i mix videos several white lines appear on every video i play.. i change the setting on video and disable "use hardware acceleration" and it took the lines away.. but now i cant use any of the effects such as the video transition or video effects, unless i enabale it again.. can anyone help me!!???
geposted Tue 02 Dec 08 @ 12:46 am
That is video card driver problem or DirectX. Update both to latest version and give it a try. Which version do you use?
geposted Tue 02 Dec 08 @ 4:05 am
to be honest im not sure.. im goin to try to update the DirectX see if it works.. i bought more memory for my laptop..to see if it was that but it didnt work.
geposted Wed 03 Dec 08 @ 8:36 pm
i update the directx and nothing.. i try to update the driver for the video card but i cant find any updates
geposted Wed 03 Dec 08 @ 9:01 pm
im using vdj 5.0
geposted Wed 03 Dec 08 @ 9:07 pm
mobsterk wrote :
im using vdj 5.0
Register ur serial in ur modify ur profile n grab the recent updates;)
geposted Thu 04 Dec 08 @ 2:30 pm
I have the same problem I think.
After 3-4 hours the video freezes and I have to disable hardware acceleration but then cpu goes high.
If I enable hardware acceleration again it doesn't fix the problem.
Only with restart of the program.
I use 5.2.1 numark cue with numark total control.
I have a laptop quore 2 2500gh memory 4g nvidia gforce 8700 vista ultimate.
Vista have the latest drivers of direct x so I don't think that direct x is the reason of freezing.
geposted Thu 04 Dec 08 @ 8:41 pm
Vista has only DirectX 10 built in, you need to install version 9 manually.
geposted Fri 05 Dec 08 @ 4:19 am
Thanks for the answer but I want to ask
how can I go back to an older direct X ?
Are you sure that this can fix my problem, or that can damage my laptop?
geposted Fri 05 Dec 08 @ 8:53 am
DirectX 9 & 10 will sit happily together in Vista and shouldn't course you any trouble.
geposted Fri 05 Dec 08 @ 8:54 am
I just installed direct x 9.0c but i don't it see it anywhere but 10.
Is it installed? Where can I see it?
geposted Fri 05 Dec 08 @ 9:47 am
The problem continues to exist.
Direct 9 didn't help, but I think it didn't get installed.
geposted Sat 06 Dec 08 @ 10:38 pm
It is, you just can't see it in Diaxdiag tool. You have problem somewhere and it is hard to find where. You should try VDJ on different video card if possible.
geposted Sun 07 Dec 08 @ 10:19 am
