Hi - I am normally quite good with anything tech but I have had massive problems in getting the Hercules MK2 working properly on either my PC or my old laptop (especially with Virtual DJ).
I have just got a new laptop and I would really appreciate it if someone could give a step-by-step guide to setting it up and getting it working using Virtual DJ so I don't mess it up again. For example, should I install the latest drivers first before I connect it?
Any help would be much appreciated, thanks!
Dave
PS - I am using Windows XP
Dave
geposted Thu 04 Dec 08 @ 10:02 am
When you install the Hercules drivers, the installation will reach a point where it asks you to plug your console in.
So I would start the installation without the console attach to your laptop, and wait till it prompts you to do so.
geposted Thu 04 Dec 08 @ 1:23 pm
Once the installation is complete, you can make sure everything is correct by looking at this document from the Hercules support site:
http://ts.hercules.com/faqs/eng/her_eng_00265.pdf
geposted Thu 04 Dec 08 @ 1:45 pm
OK thanks, I will try that as I think that part worked OK on my PC (although it just goes into an endless loop of asking me to plug it in when I try it on my old laptop!)
That PDF will be useful, cheers!
geposted Thu 04 Dec 08 @ 6:30 pm
