Hello
i have RMX DJ console , i want to be somehow more pro into this,
so i thought about adding turntables , can this be used with RMX and timecode ?
or i have to use something like numark virtual vinyl ? do i have to buy any other hardware ? or just turntables and timecode vinyls ?
thanks
thanks
geposted Thu 04 Dec 08 @ 7:10 pm
Hey,
Yes turntables can be used with the rmx and timecode vinyls, Your turntables would connect straight to the back of the RMX, using Inputs 1&2 and 3&4 then the RMX acts as your mixer, when the tunrtables are connected get your timecode vinyls on change your souncard to ASIO mode and away you go.
geposted Thu 04 Dec 08 @ 10:38 pm
You will also need VDJ Pro version for that, and you have a discount since you own RMX:
https://virtualdj.com/forums/87892/General_Discussion/_NEWS__Special_PRO_version_discount_price_for_Hercules_DJConsole_RMX___Steel_(Limited_edition_users).html
geposted Fri 05 Dec 08 @ 3:53 am
way to go!
thats the way im heading, im upgradin my mk2 into the rmx, guna see how it goes and then upgrade to pro! :)
geposted Sat 06 Dec 08 @ 7:56 pm
Hope to see ya guys on the Pro side soon :)
geposted Sun 07 Dec 08 @ 9:00 am
the guy on the shop that i bought the RMX from , told me in order to use time code vinyl i need another piece of hardware , otherwise it will not work
Confused :-s
Confused :-s
geposted Sun 07 Dec 08 @ 12:12 pm
Not sure what he is saying, you can connect your TT's to RMX and all you need is VDJ Pro, no other hardware.
geposted Sun 07 Dec 08 @ 12:37 pm
Im currently using my RMX as a soundcard and mixer, and 2 Numark TTXs + Timecodes (sometimes use VDJs and sometimes Seratos) and my laptop.
Check out the pic...
PM me ill walk you through the setup, no extra gadgets required...
geposted Sun 07 Dec 08 @ 10:03 pm
