hey everyone,
i downloaded a skin and installed it. i didnt like it. so i exited out of vdj without changing the skin back. now when i go to launch vdj i get the message invalid skin file (error in line % in the xml)
what can i do?
thanks...
what can i do?
thanks...
geposted Thu 04 Dec 08 @ 8:19 pm
I have seen that error several times. Reboot your PC see if that solves it.
geposted Thu 04 Dec 08 @ 9:11 pm
Just go to your Folder where the skins for VDJ are stored on your harddisk. Then delete the skin which gives this error and after that start Virtual Dj up. Virtual Dj will then start up with the standard skin.
Best regards.
Best regards.
geposted Fri 05 Dec 08 @ 12:02 am
tear em up. thanks but that didnt work.
i already deleted the skin from the folder. but it was physically selected in cue when it was deleted
geposted Fri 05 Dec 08 @ 6:04 am
i just reloaded cue...all is good
thanks guys
thanks guys
geposted Fri 05 Dec 08 @ 9:10 am
