Why is this happening only on ch 1? Here is whats going on, I would load the same song on both decks, cue point is at the first beat, when I play the song on channel 1 then start the song on ch 2 ,sometime after, it starts exactly where I have it cued up. The peak don't try to line up. But when I do the other way around when ch 2 is playing and I start ch1, sometime after, ch1 cue point would always try to match up with a peak on ch2. It would either skip forward or skip back, trying to match a peek on ch2. It's not even trying to match the CBG.
This is driving me nuts there is something set auto for only Ch1 where I don't want it set. And it is not skin specific.. Someone help...
Thanks for looking..
geposted Fri 05 Dec 08 @ 1:37 am
Will it happen only when you use external controller?
Check 1st with your Keyboard Shortcuts on sync shortcut, check if it is on auto, deck 1 or deck 2 or what ever then play with those shortcut settings which ever suits you.
geposted Fri 05 Dec 08 @ 2:31 am
If you were using the latest Pro version, that is option called "SmartPlay", and it is on by default when you install VDJ. To disable it, go to Start>Run>Regedit and find VirtualDJ key and set options:
SmartPlay1
SmartPlay2
and set them to 0 (zero).
SmartPlay1
SmartPlay2
geposted Fri 05 Dec 08 @ 3:35 am
Strange! I never touch anything on my registry and it's set to (0), which means the other way as you said, ALF.
I think this is not a good idea to have this setting be put only in the registry (or maybe there is other way to set it but who knows?). It will mess-up everything if you made something wicked. Those we have to think that not all VDJ users are not computer hustlers.
geposted Fri 05 Dec 08 @ 8:54 am
Thanks you guys I actually found the little button on one of the RMX skin. It was a button next to the play button and it was a "Smart Play" short cut.
Thanks again for the help.
geposted Mon 08 Dec 08 @ 1:01 am
Glad we could help ;)
geposted Mon 08 Dec 08 @ 3:39 am
