Hello,
So Ive picked up a couple of residencies in some clubs and would like to use their CDJ 1000's instead of my RMX for Djing.
I need to purchase a timecode box thingy which connects to my laptop via USB and then the CDJ's plug into this! Can anyone suggest a good reliable one?! I have been looking at the newmark one.
Also, I notice my RMX can handle inputs, does this mean the RMX can work as the box thing instead of buying one, and just use it purely as a mixer?!
Will be grateful for any help on this!
Cheers
Daniel
Cheers
Daniel
geposted Fri 05 Dec 08 @ 6:53 am
Ok thanks! :D
I went to the club this afternoon to have a play with it all there are 2 issues which seem to be happening:
1. When the pitch is changed on the CDJ it takes a few seconds for this to be updated on the VDJ software
2. Looping doesnt seem to be working very well - Very sparadic
Any ideas?
Regards
Daniel
Any ideas?
Regards
Daniel
geposted Fri 05 Dec 08 @ 11:06 am
What were your settings within VirtualDJ and the timecode config,
also did you use your RMX.
geposted Fri 05 Dec 08 @ 11:21 am
Inputs: Timecode
Outputs: External Mixer
Sound Card: RMX
Timecode settings:
VDJ Default Engine
Vinyl
33RPM
Mode: Smart
Lead Time: 500
Pitch: 500
Anti Skip and Clear Sound
Signal: VDJ Timecode (V5)
Yes that was using the RMX
Regards
Daniel
Sound Card: RMX
Timecode settings:
VDJ Default Engine
Vinyl
33RPM
Mode: Smart
Lead Time: 500
Pitch: 500
Regards
Daniel
geposted Fri 05 Dec 08 @ 1:00 pm
Dlearious wrote :
Inputs: Timecode
Sound Card: RMX
Sound Card: RMX
Next time you set up try this,
Inputs: Timecodes
Soundcard: Asio Icon <--------Uses Asio Drivers.
Soundcard(s): RMX
Might get a better response.
geposted Fri 05 Dec 08 @ 1:57 pm
If you have some residencies, i'd suggest you buy a real card instead of the Hercules toy though. There are nothing but problems with the Hercules stuff, really. Just look at how many threads there are just about that stuff...
geposted Sat 06 Dec 08 @ 4:44 am
Jimmy B, I was looking at that after I sent the message, I shall give it another go using the ASIO mode!
Van - Yeah that was my other option but decided to go with the rmx as it means i can use wither the rmx's or the CDJ's during the night, also builds in redundancy, If I were to buy an external sound card, which one would you reccommend?!
Regards
Dan
Regards
Dan
geposted Sat 06 Dec 08 @ 7:37 am
Maya-44 is a good timecode card. Audio8DJ is a higher end card.
geposted Sat 06 Dec 08 @ 9:49 am
The maya looks more in my sort of price range as its like a quarter of the price of the other lol! Will this definately work with VDJ?!
Regards
Daniel
Regards
Daniel
geposted Sat 06 Dec 08 @ 9:52 am
Yes mate it will, I use one with my TCV's.
Another good card is the Gigaport 4in/4out, it's made by ESI (the makers of the maya) but it's a slightly better card and it costs about £100-£110.
Also there is the M-audio connectiv, this is about £160, this also is a good card. It comes with the Torq software, but it can be used with VirtualDJ. I'm thinking about getting one.
geposted Sat 06 Dec 08 @ 10:14 am
Having a mess around in the club yesterday the RMX seemed to sound good with their sound system so as long as the Maya sounds atleast equal to the RMX ill be happy!
Ill see if Santa can buy me one for xmas! :D
Cheers
Dan
Cheers
Dan
geposted Sat 06 Dec 08 @ 10:18 am
