I have a Lap Top pc (Vista) and I jus got a Behringer DDM4000 Pro Digital DJ Mixer and I wanted to use this as my main mixer.I dont want to use my MK2 nomore.Trying to step my game up.What do i need to get to make this happen. I have speakers,amp,ect..Jus want to use this mixer for Virtual DJ...Ready to do clubs
geposted Fri 05 Dec 08 @ 9:09 am
The first thing u need is to upgrade to vdj pro that u have a discount;)
Hope to see u with us soon;)
geposted Fri 05 Dec 08 @ 4:04 pm
What are you going to use to actually control the decks? TCV? TCCD? Controller? Keyboard/Mouse?
geposted Fri 05 Dec 08 @ 10:58 pm
the key to useing external mixers with dj software like virtual dj is either the 'Midi Port' if your mixer has it, or using a sound card like the numark IO or the Numark virtual vinyl
you connect the mixer to the sound card and then from the soundcard to the laptop, if your guna use TCV, then make sure that the soundcard supports asio, IO and virtual vinyl do anyway
geposted Sat 06 Dec 08 @ 8:10 pm
I'm going to use tcv for now..
geposted Mon 08 Dec 08 @ 1:33 pm
I use the DDM4000 with VDJ. You need a Maya 44 sound card or any sound card that has a 4 in / 4 out capabality. In the back of the mixer, you have out A, out B and tape. Out A goes to your speakers and out B, I use another sound card, a Beheringer UCA202. This enables me to record my mix and not have the cueing being recorded. You also need a USB to Midi. I use the M-Audio Midi Sport. It works well. I hope you become a VDJ member soon.
Syberman
geposted Mon 08 Dec 08 @ 10:20 pm
sorry the nrumark io woudlent work, but the maya sound card would be a good choice
geposted Tue 09 Dec 08 @ 6:11 am
Can someone help me?
I have Virtual DJ 5 and a Dj-Tech i-mix Mixxer. I now want to synchronisize my mixxer with the functions of Virtual DJ 5.
Can u help me plz?
Sry 4 bad english^^
Can u help me plz?
Sry 4 bad english^^
geposted Tue 09 Dec 08 @ 7:16 am
Hi
Im trying to use an external mixer as my main mixer ( so i can use the eq's properly ) to mix between 2 decks plus i wont to use my Hercules mk2 aswell mixing mp3's - HOW DO I SET THIS UP PLS IM STUCK!
M
M
geposted Sat 17 Oct 09 @ 7:56 am
