Do you have any info on this card?
256MB NVIDIA GeForce 9300M GS HD
I'm thinking of buying HP TouchSmart IQ506t series PC
http://www.shopping.hp.com/webapp/shopping/computer_can_series.do?storeName=computer_store&category=desktops&a1=Category&v1=All-in-One+PCs&series_name=IQ506t_series
Will this video card give me the same problems that I'm having with my other NIVIDIA card?
geposted Sun 07 Dec 08 @ 1:21 pm
You need to make sure the pc has video out, whether it be svideo or VGA as there is no mention of video out on the site??
geposted Sun 07 Dec 08 @ 8:29 pm
Check the pics. there is svid out. But I'm concerned about if the v card will perform without restriction that we talked about with my laptop. I think I might even go with the other one. Hp IQ804t.
Brian, I’m having Discobrian24 withdrawals. Drop by gig when u have the chance.
geposted Mon 08 Dec 08 @ 4:02 am
It might work for video on Vista, but this concerns me:
"256MB NVIDIA GeForce 9300M GS HD"
It is not stated is it ddr3 or ddr2. I recommend DDR3 on video card to mix video properly.
geposted Mon 08 Dec 08 @ 5:53 am
I do agree, maybe you can email HP support and ask them exactly what it has in there.
geposted Mon 08 Dec 08 @ 2:38 pm
GDDR3 @ 700Mhz
geposted Mon 08 Dec 08 @ 3:09 pm
Man GO FOR IT!!!! You would be the 1st I know to use one of those things. :)
geposted Mon 08 Dec 08 @ 4:52 pm
Don't forget I came up with the abbreviation NTC for Total Control.
I just checked out the 25 inch and that thing is 2 dam big.
Going for the 21 inch. same specs but i'm Still waiting for a reply on if the 21 inch has ddr3 on the video card
c u on GIG
c u on GIG
geposted Mon 08 Dec 08 @ 6:27 pm
Okay. someone lied to me.
None of the units have DDR3. they have DDR2's...... The video card can not be upgraded
Question: The HP TouchSmart IQ506t series http://www.virtualdj.com/forums/action/newpost.html?topicid=100783
Ram Memory is Expandable up to 8GB so would that help any
geposted Mon 08 Dec 08 @ 7:55 pm
