Hi all
I am looking to getting a laptop and wanted to know what the min spec i needed to operate virutal dj, and operate through the radio,i get confused with celron or core etc. Am not looking to spend anymore than 400.00.
http://www.ebuyer.com/product/151493
I found this and thought it looked ok and is better than my current computer
thanks in advance
DJRJ
thanks in advance
DJRJ
geposted Sun 07 Dec 08 @ 3:14 pm
It is ok for audio use, for video you need better video card in laptop with it's own ram memory.
geposted Mon 08 Dec 08 @ 5:49 am
thanks alf, not really worried about video, just audio and surfing the net, so ram and processor are most important?
geposted Mon 08 Dec 08 @ 5:29 pm
Rob,
Would be interested how you get on with it. Especially with latency and DPC - I'm thinking I may need to upgrade myself...
Cheers,
Roy
Cheers,
Roy
geposted Mon 08 Dec 08 @ 5:46 pm
hey roy
latency and DPC ?? sorry but i am completly dumb when it comes to specs of cpu, what should i look out for?
geposted Tue 09 Dec 08 @ 5:41 pm
If only it were that simple...
I don't fully understand this stuf yet, but even on my dual core I get skipping and recently something far worse.
It all comes dowm to how well the hardware can deal with real-time audio and some hardware is better than others. I'm not even sure if its an O/S issue...
I've yet to play with my latency settings which may help, but may invest in hardware that's fit for purpose which I didn;t consider last time as I was unaware of what potentially could go wrong...
Cheers,
Roy
Cheers,
Roy
geposted Wed 10 Dec 08 @ 8:21 am
My laptop is far lower spec than that, it's a 1.8GHz Pentium4-M, a dell inspiron 8200 laptop with 640Meg of RAM.
I have installed a totally stripped down version of XP, specifically for only using VDJ - no networking, imaging, or anything else unnecessary. I don't use video, it wouldn't work anyway, but works great with audio. All my settings are for highest performance and lowest latency, and I never get any skips. The latency in DPC never leaves green.
I have a second partition I cab boot into conventional XP and surf net and do whatever else i wish.
So, you can get away with a minimal system if you spend time optimizing it...
geposted Fri 12 Dec 08 @ 3:22 am
