Hey
I was wondering if it is possible to add a playlist from windows media player into vdj ? if so how? I have many playlists created in windowsmedia player and woud prefer to use them in the automix in vdj when I'm to busy to actually mix up my own stuff.
I will be eternally grateful for any help
Thanks
Thanks
geposted Mon 08 Dec 08 @ 3:58 am
I know that playlist from Winamp can be used, the format is m3u, not sure what WM is using.
geposted Mon 08 Dec 08 @ 4:32 am
I think WMP uses .wpl files as default.
But you can also save the playlists in .m3u format.
Load the playlist into the right hand panel in WMP11.
Click on the name, choose Save Playlist.
In 'save as type', choose M3U playlist.
geposted Mon 08 Dec 08 @ 4:49 am
Thanks for the help got it all fixed up now.
geposted Mon 08 Dec 08 @ 12:58 pm
