For the first in 2 years, im getting a pop up that is asking for serial number to access VDJ?? Than it says, trying to connect to internet to check lastest version, does anybody know what or how to fix this??
geposted Mon 08 Dec 08 @ 1:57 pm
allow it to connect to interent , go get the latest update ;)
You can always turn off auto update, if you let it wait for several minutes.. (will start in the end)...
geposted Mon 08 Dec 08 @ 2:20 pm
How do i turn off auto update??
It never connected??
geposted Mon 08 Dec 08 @ 2:58 pm
open up config go to options and turn off auto update.
geposted Mon 08 Dec 08 @ 3:04 pm
See thats the problem..i cant even open VDJ to go to configure, once i click on the pop up that states "will try to connect" another pop up comes up that says installation error
geposted Mon 08 Dec 08 @ 4:04 pm
Go to your download center and redownload the software, and reinstall it on the machine and see if that works.
geposted Mon 08 Dec 08 @ 4:40 pm
No luck...i dont know if i should uninstall the program and then reinstall, but this is so frustrating, SOMEONE PLEASE HELP!!!!!
geposted Mon 08 Dec 08 @ 5:11 pm
Yes as brian already suggested, try to uninstall n reinstalled back. It might work;)
geposted Mon 08 Dec 08 @ 5:13 pm
Did you use Firefox or IE to download?? I would use IE to download and reinstall.
geposted Mon 08 Dec 08 @ 5:15 pm
No luck guys...i seriously dont know what else to do, i uninstalled the program, then reinstalled...tried to open VDJ and it asked for serial number, i type that in and than i got the pop up "installation error"
geposted Mon 08 Dec 08 @ 5:24 pm
You didnt answer my question, did you use Firefox to download?? Did you go to the download center here and REDOWNLOAD the install??
Another question is Are you using Vista, if so have you Disabled UAC, are you running as Administrator??
geposted Mon 08 Dec 08 @ 5:42 pm
I used neither, just my regular windows explorer...i got a gateway laptop but yes i went to download center, clicked on the first download with the windows 16 program
geposted Mon 08 Dec 08 @ 5:53 pm
I tried through firefox and nothing!!!!, once i redownload, it asks for serial key, i type it in, then i hit ok to open VDJ and than i get the installation error pop up
geposted Mon 08 Dec 08 @ 6:46 pm
Ok I am lost now. Maybe a Teamer can help you out.
geposted Mon 08 Dec 08 @ 7:34 pm
Thanks, i appreciate the help...ive uninstalled the program. I paid for a program here and it doesnt even work, i dont know if i should buy another system and try that way or just get a new system over all, but any help i can get i would appreciate!!!
geposted Mon 08 Dec 08 @ 8:01 pm
I am using Windows XP, i have yahoo if you do to??
geposted Tue 09 Dec 08 @ 9:28 am
hey guys, i think i have setup my bcd2000 properly, after a bit of hassle due to vista
anyway i open up vdj 5.1 or whatever i have, and go to config, in the controllers tap it recognises the bcd and says its activated, but i cant get it to sync with vdj, like it just sits there and does nothing
what do i do?
what do i do?
geposted Mon 16 Mar 09 @ 1:25 am
