FROM THE MANUAL :
_______________________________________________________________
22. SHIFT - Used with the looping feature, the
shift switch allows you to cut your loop in
half or double it. If Smart Loop is on you will
be limited to a minimum length of 1 beat.
Anyone who knows how to activate the smart loop function on the ICDX ??? in the manual is showed only that the function exists.... but not how to activate it. Thanks in advance lele...
geposted Tue 09 Dec 08 @ 4:20 am
I think the smart loop feature might refer to using the Numark 5000fx with the icdx where the "Smart Loop automatically truncates sample to beat"
http://www.topdjgear.com/nuicdidjdrsy.html
I have 2 icdx's I only know the normal loop and shift commands with them.
geposted Tue 09 Dec 08 @ 6:04 am
ok thanks.
I'm PUZZLED ...... is it mine manual the only with the word "Smart Loop" (and its meaning) at chapter 22 ..... ????????????????????????
geposted Tue 09 Dec 08 @ 10:50 am
Its in the latest online manual.
Check out other manuals, info, video links and download updates for your icdx at http://www.numark.com/icdx
geposted Tue 09 Dec 08 @ 5:22 pm
no, no other usefull information i found on the site (numark.com). I would like to confirm that the information i've seen is as in the manual on the web as in the paper one,, of mine. I found the same info, another incorrect sponsor about "SEAMLESS LOOP" in section "KEY FEATURES" at this link http://www.numark.com/icdx .
I'm very very angry for this. Is That the numark engeneers does'nt know what they write on the official site about a product ?
ALSO they DO NOT answer me for 3 times at the mail i sent to them. I'm very determined to see the end of this incredible story.
Emanuele Della Torre.
geposted Wed 10 Dec 08 @ 10:18 am
