ok my sound card keeps giving off this poping sound.. id ont touch anything and it keeps poping..when i move any knobs from my mixer it pops even more..why is this happening..i just noticed this right now...i dont want to go to no gig with that nasty sound..
PS im using the NUMARK DJ IO sound card...i also hear this popping sound thru my headphones..i dnt think its my headphones and speakers..
geposted Tue 09 Dec 08 @ 2:20 pm
What your Performance settings,
You could try this,
Preset slider all the way to fastest, Latency on Auto
Safe mode and Overclocked unchecked
geposted Tue 09 Dec 08 @ 2:23 pm
Which mixer?? external or the total control?
Just disable the safe mode n u should be fine if u using from the latter;)
geposted Tue 09 Dec 08 @ 2:29 pm
yea im using the total control so i take of safe mode..ok i will...whats latter.. :/?
ok i hear it still but less...im ganna see what i can do to loose it completely...
geposted Tue 09 Dec 08 @ 2:31 pm
Have u also tried jimmy suggestion? Preset to fastest n latency auto.
geposted Tue 09 Dec 08 @ 2:53 pm
yes i tried it and it sounds better...; D
geposted Wed 10 Dec 08 @ 9:49 am
So this is solved then;)
geposted Wed 10 Dec 08 @ 2:08 pm
YUP :D
geposted Wed 10 Dec 08 @ 2:23 pm
