Okay guys, the ejective here is to build a Compact VJ/DJ PC with a Touch screen
Links - Suggestions - thoughts about hardware, help making this thing to be very very low profile.
Lets get this thing built.
This monitor I found for $590.00
http://www.superwarehouse.com/Elo_TouchSystems_1939L_19_LCD_Rear_Mount_Touch_Screen_Monitor/E171252/ps/1509595
Looking for I thing they call them FLEX Power Supply’s
Thanks
Thanks
geposted Tue 09 Dec 08 @ 5:15 pm
The response time on that monitor is a bit high, mine is at 8ms and that one is at 22ms.
Those power supplies wont be enough power, you need at least a 650w power supply with dual 12v rails.
geposted Tue 09 Dec 08 @ 10:23 pm
19" not 17" please
http://www.newegg.com/Product/Product.aspx?Item=N82E16824105004
If there even a better one out there for a little more that would be fine
geposted Tue 09 Dec 08 @ 11:24 pm
That one is the same as mine but 19, the only thing I couldnt do was get the software installed for it, but found it worked better with the drivers Vista installed.
Stop typing so large and bold
geposted Wed 10 Dec 08 @ 12:22 am
I don't really understand you can't use the software that comes with the 19". WHy?????
Response Time; That frightens me. 8ms??? Are there Monitors that have less than 8ms??
geposted Wed 10 Dec 08 @ 1:47 am
I found three on newegg, all 5ms. Pich the better of the three. Never mind the price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824016107
http://www.newegg.com/Product/Product.aspx?Item=N82E16824016113
http://www.newegg.com/Product/Product.aspx?Item=N82E16824217059
geposted Wed 10 Dec 08 @ 2:10 am
HARD DRIVE
Seagate Barracuda 7200.11 ST31500341AS 1.5TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148337
MOTHERBOARD
Suggestions Needed. Is Quad-Core over kill?
CPU
Need suggestions.
RAM
Need suggestions.
VIDEO CARD
Need suggestions.
TOUCH SCREEN MONITOR
geposted Wed 10 Dec 08 @ 2:08 pm
No review on this but I found it with a coupon for $525. What do you think?
http://www.techforless.com/cgi-bin/tech4less/process
geposted Wed 10 Dec 08 @ 4:25 pm
There is nothin in that link
geposted Wed 10 Dec 08 @ 6:05 pm
try this
http://www.techforless.com/cgi-bin/tech4less/997-3985-00?id=mAb2buXw&mv_pc=80
geposted Wed 10 Dec 08 @ 6:15 pm
