Hey Everyone,
I have searched high and low but can't figure this out.
When you are using a playlist and VDJ is auto mixing the tunes from the list, the current song playing is selected by a light blue colored highlight. The HEX color is #A6CAF0 to be exact. This color does not appear in any .xml file. It does not seem to be in the bitmap either. Where does this color come from and can I change it?
This has caused a few sleepless nights. If you are using a light grey font, you can't read the text if it is highlighted.
Would anyone have a suggestion?
Many thanks,
-DGee
Many thanks,
-DGee
geposted Tue 09 Dec 08 @ 10:00 pm
This color is directly coded in the skin engine. It isn't customizable.
geposted Wed 10 Dec 08 @ 2:39 am
is thear a wa tu customize THE TOP VWEFORM you know the blue one and the red one?
geposted Wed 10 Dec 08 @ 4:41 am
Yep. It's a skin element, which can be of any color / gradient.
geposted Wed 10 Dec 08 @ 10:55 am
can u tell me whaer is it located in the XML i mena what does it say so i can change the color
U know like author/title=scrol/yes font-bla bla/color-0654aa
geposted Sat 13 Dec 08 @ 12:42 pm
Rhythm :)
geposted Sat 13 Dec 08 @ 2:43 pm
jerem k thank you ver much u are good man indeed
geposted Sun 14 Dec 08 @ 4:52 am
jerem k i have founded the rithm but i cant find the color of it can u be a litle more specific
geposted Sun 14 Dec 08 @ 4:55 am
The rhythm element has alot of different parameters.
Some parameters are to determine it's size and position, and all other parameters describe the position in the bitmap file of the colors (pictures) to use.
geposted Sun 14 Dec 08 @ 9:03 am
so basili it is very har to change the colors of the rithm cuz i was just thinkin of changing the blue in like yelow and red in the i dont know green
geposted Sun 14 Dec 08 @ 10:58 am
