Twice last night, and on other occasions my VDJ crashed while I had it playing in auto-mix mode - I was absent from the console every time. I dawned on me that it may have been triggered by my screensaver kicking in. Does that sound reasonable?
Jay
Jay
geposted Wed 10 Dec 08 @ 2:19 pm
Yes.. it could be. It's better not to have screensaver enable on ur gig system.
Do have ur crashguard and post it here.
Regards;)
Regards;)
geposted Wed 10 Dec 08 @ 2:59 pm
crashguard?
geposted Wed 10 Dec 08 @ 3:10 pm
hehe,, yup the crash guard report;)
U indicated that ur VDJ crash, so when it crash it generate a report. It is located at ur documents >VDJ folder :)
What OS r u using?
Regards;)
What OS r u using?
Regards;)
geposted Wed 10 Dec 08 @ 3:24 pm
OH.. thanks. I forgot where the report was. I'll have to check it. Using Vista
Jay
Jay
geposted Wed 10 Dec 08 @ 4:05 pm
Vista has a nasty feature called UAC...
If screensaver or other program takes focus, other software can freeze, because it always asks/or kind asks, for user input, to allow program to run or not...
Turn off UAC .. :)
http://www.howtogeek.com/howto/windows-vista/disable-user-account-control-uac-the-easy-way-on-windows-vista/
geposted Wed 10 Dec 08 @ 4:54 pm
Thanks... UAC has been off.
OK here is the crashguard from last night: Thread=Main, Dump=8b421451, excode=0000005 (0, 5c,4e)
Does that mean anything to anybody?
Jay
Jay
geposted Wed 10 Dec 08 @ 9:49 pm
