I was looking into buying a setup and I'm trying to save some money and it looks like you have a digital to vinyl interface. I was wondering if you could use the software + timecode vinyls and like a standard mixer with a USB connection to do it instead of buying a $300 dollar extra interface. Thanks.
geposted Wed 10 Dec 08 @ 10:49 pm
All you need is the software, a 4in/4out soundcard, such as a Maya 44 (about $120 in your neck of the woods) a pair of TCV's and you are sorted.
Any 2 channel mixer (or more) will work.
geposted Wed 10 Dec 08 @ 11:18 pm
I'm confused does the Numark DXM01USB work as both a soundcard and a mixer?
geposted Wed 10 Dec 08 @ 11:28 pm
Yes it does, but it doesn't have the inputs needed for using Timecodes. You need to have 4 inputs, 2 for each "deck"
geposted Thu 11 Dec 08 @ 12:27 am
What hardware does?
geposted Thu 11 Dec 08 @ 12:35 am
If u need a mixer cum soundcard.. take a look at hercules rmx or mk2 etc..;)
geposted Thu 11 Dec 08 @ 6:01 am
