I downloaded VDJ 5 and the skin is to small.
I just swapped over the VDJ folder from my documents from my other (old) computer to my documents on my new computer and iam not sure how i can get the 1280 x 800 resolution skin i need?
Cheers, all help much appreciated, well sorta but not.
geposted Thu 11 Dec 08 @ 3:13 am
Look here man https://virtualdj.com/addons/skins.html ;)
geposted Thu 11 Dec 08 @ 4:52 am
You can also use the Skin Resizer Tool:
https://virtualdj.com/addons/4442/VDJ_Skin_Resizer_Tool.html
If you would like to resize a skin from 1440x900 to 1280x800.
geposted Thu 11 Dec 08 @ 6:23 am
I looked there. I thought it would come with the download or an option in the account settings or something.
Yeah i seen that resizer tool.
Loooks like i have to use that, cheers for the helps. Mods.
Yew, you go hard.
...., that resizer tool wont work if the skin is 1024 x 768.
F*ck no skin.
Excuse the language.
Wheres the VDJ 5 1280 x 800 skin.
Yew, you go hard.
F*ck no skin.
geposted Thu 11 Dec 08 @ 11:00 pm
An Intermal mix Widescreen is ok for you?
https://virtualdj.com/addons/2839/VDJ4_InternalMixer_Widescreen.html
geposted Fri 12 Dec 08 @ 1:55 am
It does'nt install.
It says software not installed.
I just switched from my old PC to new and installed VDJ5 on my new PC on a seperate user account but aim logged onto that account.
Whats the problem.
Cheers.
Lee.
Whats the problem.
Cheers.
Lee.
geposted Sun 14 Dec 08 @ 8:48 am
Heya and we have congrats, success, f*ck i dont know dfkjsssss, fijslf
It worked
cheers for all the help, man i gotta not stay up so late.
Peace.
aekfhekjdsf
ffff
fdsd
It worked
Peace.
aekfhekjdsf
ffff
fdsd
geposted Mon 15 Dec 08 @ 7:17 am
dsfsdf
This the same skin as the VDJ5 skin it loooks tha sames?
Cheers.
fsd
Cheers.
fsd
geposted Mon 15 Dec 08 @ 7:21 am
