Topic: Annoyance in searching these forums
When searching for anything in these forums, the "More results exist. Refine your search with more words to narrow the result set" message appears at the bottom. So when I refine the search, the same message will appear yet again. This makes the task of searching these forums very time consuming.
Is there any reason for having it this way? Maybe you can increase the filtering so we can scroll through more results? (i.e. if more than 10,000 results appear, then you are required to refine the search)
Thanks.
geposted Thu 11 Dec 08 @ 3:10 pm
yes, the search can be improved.
Its on the list of things to do ;)
Please add ability to check out all the new posts since last visit!
Most people can agree that google is a pretty powerful search engine. I've seen sites that use google's search capabilites for their searches. Not sure if this can be applied to the VDJ Forum search.
But, in the meantime, you can try this trick with google.
In the google search box, type in whatever it is you are trying to find on the VDJ Forum, and then add this after it: site:virtualdj.com/forums
i.e.- you want to search for timecode vinyl and mk2. google the following: timecode vinyl mk2 site:virtualdj.com/forums
This narrows google's search to only the pages that fall under virtualdj.com/forums.
You can do this for any web site.
Hope it helps!
nice tip...
Good old google, lol
and i'm googling now...
