Anybody from Romania?....Cineva din Romania?:)
geposted Fri 12 Dec 08 @ 6:53 am
Hi there, u may use the user map to see others near you;)
https://virtualdj.com/users/
geposted Fri 12 Dec 08 @ 7:15 am
Thx man...but there`s no one on the map...nowher in the world...:-). Maybe I don`t know how to use it.
geposted Fri 12 Dec 08 @ 9:38 am
Try to select the option 20 user or more;)
geposted Fri 12 Dec 08 @ 1:14 pm
If you are using Firefox as your browser, you won't, it's never worked for me. Try using I.E. and you will see the user pins ;)
geposted Fri 12 Dec 08 @ 2:00 pm
Thx jimmy...u`r right...mozila dosen`t work. I.E. worked.
geposted Fri 12 Dec 08 @ 2:12 pm
