Is anyone experience noise in the jog wheel you are cuing music on? Ex. Right side is live, left side is in cue mode. When I manipulate the jog wheel or any of the dials on my ICUE, I can hear "noise" in the speakers. The noise also records into the file when I am recording a set.
Any ideas?
Tech Notes:
Soundcard: Soundblaster Live 24 bit (Multiple ins and outs)
ICUE Virtual DJ console
VDJ Software (Noise can also be heard when using software that came with ICUE)
Any ideas?
Tech Notes:
geposted Sat 13 Dec 08 @ 10:26 am
Problem solved. I changed the latency settings in the config and got rid of the noise. I unchecked Safemode.
geposted Sat 13 Dec 08 @ 4:03 pm
