Hi all.
Firstly give thanks to all for reading and helping me.
Days ago, I bought the Hercules DJConsole Rmx wich comes with a Limited Edition VirtualDJ. Allrigth here...
But... When I unistall the Limited Edition and install the Pro Edition that I had from a severals weeks, the Console doesn't work...
I have downloaded all the upgrades of drivers and HDJC interface.
I Don't know what to do, it's doesn't work. I select ASIO system, and it doesn't work.
Please, need your help, I need work with it...
Thanks you all.
Regards,
Fersu.
Thanks you all.
Regards,
Fersu.
geposted Sun 14 Dec 08 @ 9:31 am
Hi fersu, pls register ur pro serial in ur modify ur profile. If u did not have it, do use the trial version that is available here;)
Abt the problem u having, do enable the herc icon in the remote tab;)
Hope to see with us soon.
geposted Sun 14 Dec 08 @ 10:00 am
Thanks!
But I have activated all options in Hercules section and this and doesnt work :(
geposted Sun 14 Dec 08 @ 10:33 am
What version r u using?
geposted Sun 14 Dec 08 @ 10:47 am
What version of the Pro Edition are you using anything less than 5rev7 and the RMX will not work.
Please try the latest demo of VirtualDJ
geposted Sun 14 Dec 08 @ 10:50 am
Hey
Im using 5.0 Version. On options menú, the Hercules sectio appear with a red ligth
Thanks
Thanks
geposted Sun 14 Dec 08 @ 10:52 am
That's why it won't work, you need version 5rev7 or over.
Again, please try the latest demo or buy a licensed copy of VirtualDJ
geposted Sun 14 Dec 08 @ 10:57 am
Thanks a lot :D
I will register now. Thanks for your time.
geposted Sun 14 Dec 08 @ 10:58 am
Yes once u registered, u may upgrade to the latest version:)
geposted Sun 14 Dec 08 @ 11:07 am
Per the above statement, is limited edition not a purchase(licensed) copy,
geposted Wed 07 Jan 09 @ 2:06 pm
It is licensed, but it is not a full (Pro) license copy that will have many more features n benefits that are not available for the limited edition;)
geposted Wed 07 Jan 09 @ 2:21 pm
Yes it is - but the user said they had the Pro Version which was not registered.
geposted Wed 07 Jan 09 @ 2:27 pm
