Well my 2nd set of Pioneer HDJ-1000 and my pair of Technics 1200 finally bit the dust. What is the best buy today that are solid and great sound?
geposted Sun 14 Dec 08 @ 5:59 pm
I'm in love with mine......
http://pro-audio.musiciansfriend.com/product/Denon-DNHP1000-Professional-DJ-Headphones?sku=247043
geposted Sun 14 Dec 08 @ 6:19 pm
Mybe i'm too hard on headphones... i also had the Denon 1000's last year. One side the cup broke then the wires tore apart. i also found them too high endy in frequency.
geposted Sun 14 Dec 08 @ 6:34 pm
I have talked with many people about headphones, all of them said to me that Pioneer HDJ-1000 are too fragile and it breaks very soon at the coupling as showed in this picture:
I suggest you to buy Sony MDR-V700DJ but to avoid and buying them by ebay because there are many fakes (even though are the same as shape, electrical components are differents).
Technics RP DH 1200 are good as well.
geposted Sun 14 Dec 08 @ 6:38 pm
They're not the most popular brand name; but I've been using Behringer HPS5000 headphones for the past year.
I've dropped them a couple of times, and they seem to be holding up very well.
geposted Sun 14 Dec 08 @ 6:57 pm
Both my Pioneers broke in the same place.....
geposted Sun 14 Dec 08 @ 7:33 pm
So if you are looking for a headphone which can last and at the same time it has a deep sound, you should decide either Sony or Technics.
This depends on you:-)
I picked Sony and I've never regretted my choice.
geposted Sun 14 Dec 08 @ 7:38 pm
I also had the behringer headphone and they lasted the least amount of time. The construction wasn't the problem, the coils tore apart and the headphones started distorting. I DJ almost 7 nites a week so I go through headphones very fast. but I'm sure there 's aset of phones that are well built at the swivel joints and electronically.
The best ever headphone I owned for over 15 years was a pair I purchased at Radio Shack in the 80's. never a problem, they actually got stolen at a gig. No swivel or gadgets, just well built and a decent quality of sound at the frequence I needed to hear to do great clean mixes! Man, I miss them...
geposted Sun 14 Dec 08 @ 7:40 pm
I recomend you the AKG K181DJ...the sound quality for me is better than the reference sennheiser HD25, and ALL the pieces of this headphones are available as spare parts, so, if something brokes, just called your AKG distributor, to get the replacement piece!
geposted Sun 14 Dec 08 @ 7:48 pm
Cool... my son also told me to check them out. Thanks
geposted Sun 14 Dec 08 @ 9:03 pm
Has anyone tried or own a pair of these headphones? Wesc Bag Pipe Dim Mak bagpipe. I was recommended to try them out by a dealer in Montreal today...
geposted Sun 14 Dec 08 @ 9:22 pm
i want some soooo bad... very rare, bout 200$ Us and damn are they sexy ;)
lol 57mm drivers... biggest ever heard of and i hear they're outstanding.
btw... anyone selling a pair of headphones? ;)
geposted Sun 14 Dec 08 @ 10:32 pm
I would buy a new set rather than a used one.. but this is me;)
geposted Sun 14 Dec 08 @ 11:34 pm
true true... but they can be $$... lol
and i trust the users here more than sellers on ebay lol
geposted Sun 14 Dec 08 @ 11:44 pm
i got these...and when im done using them they straight into there PIONEER bag that comes with the headphones. NOBODY I REPEAT NOBODY TOUCHEZZZ these headphones but me...i put them away and i take kare of them..
geposted Mon 15 Dec 08 @ 7:20 am
If you want a pair of headphones that are robust try these
Sennheiser HD25 SP
Quite basic in design, but the sound quality is really good and quite bassy too. I've had a pair for well over 9 years now and all I've had to change is the cable and ear padding twice.
Sennheiser HD25 SP
geposted Mon 15 Dec 08 @ 9:18 am
+1 Spinna, I will not even use a pair of the studio headphones when I go to the radio station. I always bring my own. Lots of funky things growing in other peoples ears......
geposted Mon 15 Dec 08 @ 9:25 am
http://www.ultrasoneusa.com/ try this link
I reccomend
ultrasone dj1 ck them out at djdeals.com they are great and if you mix cloes ear through headphones like i have to sometimes you will notice the diff ..Its a matter of prefrence if you want loud loud headphones I recomend the stanton but they arent that rugged .. im know as headphone killr Dj Jamm so believe me Iv gone thought way to many hdphones including the sonys . so far ive had the ultrsones for 2.5 years thats a record for me .. i was lucky to ever get 6 months out of a pair..
I reccomend
geposted Mon 15 Dec 08 @ 8:25 pm
ok ok... i finally bought a new pair of v700s for 98.99 on musiciansfriend... will tell you my review.
never have used DJ headphones. been living off sony earbuds and skullcandy gift ones from last year. ready to feel the difference ;)
geposted Mon 15 Dec 08 @ 11:09 pm
Sennheiser HD25 SP
Sennheiser HD25 SP
Jimmy I have used the exact same headphones for around 7 years with the main cable replaced once. Bought from Richer Sounds for £60! They made a mistake with the price on their website and had to honour it. :-) I modified mine by turning the cups upside down and running one of the wires over the headband (held by good old tank tape) so that the cable only exits from one side. The current main cable is getting dodgy again, thought it was VDJ at first. Thinking of trying those AKG's above.
geposted Tue 16 Dec 08 @ 5:06 am
