Hello,
I've been trying to add the EQ shortcuts on my keyboard, but it's not really working properly. For example, I add the "bass" on deck 1 and set the value to "-4" to the shortcut "CTRL+B". Then I add "bass" on deck 1 and set the value to "+4" to the shortcut "CTRL+M", and use "CTRL+N" as "reset".
Theoretically, it's supposed to work where when I press and hold "CTRL+B", the bass eq knob will turn the bass down. But it doesn't work that way. It actually moves it once to the right but never again. I try to press "CTRL+M" and it doesn't move at all. Though I do press "CTRL+M" and it does center the bass EQ. How can I get this to work properly? Am I missing something?
Thanks
-Renato
Thanks
-Renato
geposted Sun 14 Dec 08 @ 9:31 pm
Yeah, don't push and hold, you have to keep releasing & pressing the key :)
Also try a bigger value like 32, 64 or 128.
geposted Mon 15 Dec 08 @ 3:34 am
I think I set my shortcut at a value of 3400 to raise the treble to 3/5 on the slider.
geposted Mon 15 Dec 08 @ 6:48 am
Yeah, it was definitely the higher values. Thanks!
geposted Thu 18 Dec 08 @ 6:42 pm
