I was using vdj 4.3 and there was a folder called local database where you clicked and added search HD and all your files came up and when you typed the name of a song you were searching it appeared...
in VDJ 5 there is no such folder... and i have no database at all... i go to the browser and click check, fix or clean database but nothing happens... i suppose that all my files shoul appear on the search window but nothing happens... if i search in the folders at the left and click one that has many songs and i want to find a particular one that i know is there and type it on the search square nothing happens.. what shall i do? i have a gig on friday and i really need this to work!!!
geposted Sun 14 Dec 08 @ 11:36 pm
Pls register ur serial in ur modify ur profile n updates to the latest version;)
geposted Sun 14 Dec 08 @ 11:39 pm
Exactly the same problem for me. VDJ does not save the database. Any ideas anyone???
geposted Mon 15 Dec 08 @ 7:17 pm
i have this problem too. no one has answered this post
geposted Thu 26 Mar 09 @ 1:12 pm
I just upgraded to a MacBook Pro and have the same problem...can't save the DB...can't pick the DB from the list in the config menu
geposted Tue 07 Apr 09 @ 9:07 pm
