Hi,
I have received a power point presentation of pictures with a song to be played at a wedding. How do I convert it to make it play in Virtual DJ? This was given to me by the bride.
geposted Tue 16 Dec 08 @ 1:46 pm
its easy simply go back to the bride and tell her you can't play it or just google powerpoint to video converter.
geposted Tue 16 Dec 08 @ 2:57 pm
I think you can use Microsoft MovieMaker to convert the PPT to wmv.
geposted Tue 16 Dec 08 @ 4:33 pm
Pm me. E-mail me the powerpoint, i'll convert it and send it back.
geposted Tue 16 Dec 08 @ 7:52 pm
I use CAMTASIA STUDIO to convert a power point to mpg.
geposted Tue 16 Dec 08 @ 9:20 pm
If you have powerpoint, one option is to go file / save as, then in the "save as type" drop down box choose JPG. It will save each slide /photo as an individual photo and you can run it as a slideshow in VDJ while playing the music file (if you have it).
Could try this http://www.softinterface.com/Convert-PowerPoint%5CConvert-PowerPoint.htm but ive never used the program to convert.
geposted Tue 16 Dec 08 @ 9:54 pm
If I remember correctly, MS Powerpoint has an export feature.
Try loading the powerpoint and seeing if you can export it to MPG format.
geposted Tue 16 Dec 08 @ 9:55 pm
i have a mac and powerpoint has a 'save as movie' which saves it as a quicktime movie
geposted Wed 17 Dec 08 @ 12:38 am
I've used camtasia as suggested above and it definitely does it.
geposted Wed 17 Dec 08 @ 6:07 am
camstasia.. will work..give it a shot mon
geposted Wed 17 Dec 08 @ 6:30 am
