Forum: VirtualDJ Skins
Topic: MIXMASTER (v2.0 now available) - Page: 1
just a quick preview of a new skin i created. Suggestions are welcome.
geposted Tue 16 Dec 08 @ 2:33 pm
very interesting ;)
very simple skin. Good for controllers.
i like the 2 songs but i would chankge the spining disks in to something else this radar is too futur for me
VYNIL yeag thats goodput in a vynil
Its not a "radar" look. Some heavy scratchers use a visual reference instead of an audio cue point. The line helps them see where they are on the track.
Very simple. I mean its good for Timecode and Controlers. I like it :-)
some heavy scratchers dont use VDJ the real ones the old school but i think if u ot a cue poitn in audio u can se when its coming
Me too.
I like the large browser aswell.
it looks very interesting. can't wait to try it out.
godspeed listen2
I know the purpose of the CBG is to set it (if needed) and be able to match without overlapping waves but i like to see the peaks like up also when they are next to each other also.
Does anyone think that deck#2 wave and song info text should trade places, making the red wave closer to the blue? I think visually it would make sense to have them closer. I think i might also move the CBG grid box to the bottom border just above the browser.
I am going to move some things around, I like it as is but it does not feel 100% perfect to me. Hot cues and TC mode will be added. Does anyone also care about UV meters? they are mostly for display since with external usage you really dont need them.
Yes, I think that may look better, the CBG box makes it look a bit cluttered where it is now mate.
Good opinions... I will move things around soon.
I think what you mean is to have side by side waves, i did with the original turntablist skin but found it not as useful for a visual beatmatch. one wave on top of the other works better since you can still see seperate waves but also align them up. ;)
+1
Nice skin L2;)
Looking forward to use it;)
I am going to swap the red deck around and release this as a beta....soon.
Then with the help of those interested "we" finish
too bad i cant use it and i have a controler..
Are you using the Skin Creator to do all the xml of the skin?
I M ABOUT TO MODIFI THE DEAFULT VED skin just ading a EQ and a biger crossfader and i can tell you its hard as hell im doing t all by hand no MODIFIER to help me
i pretty much do it all the "hard way" I use Note pad for XML and paint.net for the images.
Well, here's a progress report. In between getting my ass ka-kicked by a snow storm and another to follow tomorrow, I have done some work on the skin. I'm not sure i love the hot cue buttons but i might at least make them smaller. Let me know ..
19%
