Hi all, I am hoping that someone may be able to help.
I am using Numark CUE and are experiencing the video locking up / freezing after a duration of about 10 - 20 seconds.
I am using the latest release of CUE and the PC specification is as follow:-
AMD Shuttle 3Ghz CPU
1GB Ram
512 Graphics Card
PCI Sound Card
I have searched the forum on here and can not find any help in resolving this issue. I have also dropped a line (ticket pending) to support but nothing back (24hours).
Any help would be appreciated.
Many thanks.
1GB Ram
512 Graphics Card
PCI Sound Card
Many thanks.
geposted Thu 18 Dec 08 @ 4:45 am
Update...
I have an identical PC and are experiencing the exact same problem.
I am scratching my head here and can not understand where the problem may be.
Latest graphics card drivers installed from Nvidia.
Still nothing back from my ticket to tech services :-( (48hours now)
geposted Fri 19 Dec 08 @ 5:23 am
Single core or Dual Core. If you are mixing video then Dual core processer is a must IMO. You may need to upgrade if it is a single core.
leerichmond wrote :
1GB Ram
Again mixing video you need at least 2GB of Ram. You may need to upgrade
leerichmond wrote :
512 Graphics Card
You say it's a Nvidia card in your second post, but what series, 8 series by chance.There is a known problem the Nvidia 8xxx series cards and VirtualDJ, which causes minor freezes.
What OS are you using XP or Vista, also is your DirectX 9c up to date, VirtualDJ uses this app.
geposted Fri 19 Dec 08 @ 6:43 am
Hi,
Update since last post.
Spec:-
Shuttle 3.2ghz CPU (Single Core) - Video works ok on 1.7 CPU (Older system I am using with no problems)
2gb RAM Now installed - Video works ok on 1gb RAM (Older system I am using with no problems)
GeForce 7300 GS DDR2 256mb Card - Video works ok on older 128mb (Older system I am using with no problems)
Windows XP
Very latest version of Directx
I am confused where my old PC system runs everything ok but a new PC is falling over.
Any more ideas.
Spec:-
Windows XP
Any more ideas.
geposted Fri 19 Dec 08 @ 10:15 am
Well it all depends on what you have got a your newer PC, such as programs, services, anti-virus and crap like that
But I would look into installing a Dual core processers
geposted Fri 19 Dec 08 @ 10:21 am
leerichmond wrote :
Hi,
Spec:-
Windows XP
Any more ideas.
Spec:-
Windows XP
Any more ideas.
Did you get any updates on the ticket we discussed?
geposted Mon 22 Dec 08 @ 8:36 am
