I want to use virtualDJ as well as ms pinky, so that i can create my own applications in max msp, if i purchase the virtualdj package including the soundcard, will i be able to use the numark soundcard for other aplications. I know i need ms pinky vinyls but will i need a different soundcard?
geposted Thu 18 Dec 08 @ 7:26 am
VirtualVinyl sound card will only work with VirtualVinyl, CUE, and VirtualDJ.
geposted Thu 18 Dec 08 @ 7:43 am
ah poo
geposted Thu 18 Dec 08 @ 7:22 pm
you could look into the Maya 44 USB...it's VDJ compatible...check ms pinky, though...
geposted Fri 19 Dec 08 @ 9:29 am
