Forum: Old versions
Topic: Synaptics Touchpad 2 MIDI - Page: 1
If someone have the common Synaptics touchpads please test it ;)
Touchpad 2 Midi is a free VST plugin for Windows that allows you to use the touchpad on your laptop as a midi controller.
The touchpad can be configured as:
* An XY pad
* 4 sliders
* 4 Buttons
At the moment only Synaptics touchpads are supported - we are working on adding support for USB touchpads as well, but have not yet heard from Cirque / Adesso regarding how to read raw data from their touchpads. Some laptops use Alps touchpads these are unfortunately not supported either - Apls have been contacted.
Host compatibility
http://www.livelab.dk/touchpad2midi.php
geposted Thu 18 Dec 08 @ 7:32 am
I've Synaptics.
Where should I copy the .dll file?
What are CH and NUM?
Like a common VST you can copy into Document\VirtualDJ\Plugins\SoundEffect
but if you try to read the instruction you can use SAVIhost http://www.hermannseib.com/english/savihost.htm or any ather VST Host program to open the VST with another external program because I don't know if VDJ can manage this VST for this strange use.
CH is the midi Channel number I hope.
I will try with my home pc this evening but in the meanwhile some other Exp user can try if it works! ;)
I copied the .dll file into soundeffect folder but when I enable it, the sound of the song goes OFF.
Another thing:
in information field of the effect, there is written
"DESCRIPTION: Incompatible VST plugin! (requires 0 IN and 0 OUT)"
But I have no idea what it means:-(
Ok.
As soon as I have any news, I'll post here!
Rock ON!!!
It work very well :)
It does indeed, nice find :)
cool find , i'm gonna try it ...
Cioce do you have any tutorial about this?
Sorry but no time to do it...
Have you tried by yourself? Experienced user are generally Expert on this things or not? :)
I tried but it doesn't wok:(
I've downloaded it...I'll give it a go when I have a little time ;)
Do someone have an idea if a common touchpad HID mouse can be mapped like an HID controller in Virtual DJ?
I don't want to install virtual midi driver
hmm that's a good question actually, I have used the above app before and it works great (use it as a standalone app). If I get some free time I might try this idea out.
UP, anyone can help?
i will give it a try to map to the Touchpad..
but i think with a midi emulation it goes easyier :)
In waiting for an HID support for Synaptics Touchpad here the simple VDj 6 "Generic MIDI mapping.xml"
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="SIMPLE_MIDI" author="Atomix Productions" description="Simple MIDI wrapper" version="602" date="17/10/2009" priority="-10">
<map value="MIDI_CLOCK" action="off" />
<map value="0-CC0" action="effect slider 1" />
<map value="0-CC1" action="effect slider 2" />
<map value="0-CC2" action="param_greater 0% ? effect active on : effect active off" />
</mapper>
Ps. Thanks to Moramax for the help about action param_greater
thank to you cioce.;)
Since in my case I have another file named "Generic MIDI mapping.xml", how can I name this file?
87%
