hy
i' m new here on the forums
i've got i req.
i bought recently a hercules dj control mp3 , i installed virtual dj console ed. , entered the serial license , but i've lost the cd
i know the serial is stored somewhere in reg files . can i retrieve it ? or is it in program files ?
thks in advance
i've got i req.
thks in advance
geposted Thu 18 Dec 08 @ 8:00 am
Since you never registered the serial on the site ... there is nothing we can do for you here.
If you purchased the console - NEW - then you should be able to contact Hercules ( www.hercules.com ) and they may be able to cross-reference the console serial number to the software serial.
If you purchased the console - USED - then you can still contact Hercules - but you will not be able to register the serial here if the previous owner had already registered it.
Hope that helps ...
Chris
Hope that helps ...
Chris
geposted Thu 18 Dec 08 @ 8:18 am
