I am having a slight issue being unable to display the lyrics on my computer. i will select the song and the video box will open and the song will start but the lyrics wont display, it will have a black screen and wont show anything.
Im not sure what to do at this point. it works just fine on my other computer so im out of ideas. could it possible be a codec issue or maybe the graphics card?
my graphics card in my other machine is a ATI Radeon 9700 Pro. I dont think this should be an issue. please help, thanks so much.
geposted Thu 18 Dec 08 @ 3:55 pm
do you have directx installed, if it plays in windows media you have the codec and are the drivers installed for your card, also have you checked the video box in config
config > video > check box > in drop down window select the card you want to use.
geposted Thu 18 Dec 08 @ 6:08 pm
