I'm using the skin Mix Lab V3.1 which came with Virtual DJC version 5.2.1 and find that the Hercvules RMX hardware to DJC software mappings are not accurate.
For instance if I turn down the bass on the RMX on an in-coming track a quater turn to the left of top dead centre, and I cross fade and start turning the base back to top dead centre, the DJC software lags and has the bass just left of top dead centre.
Having any of you experienced the same and if so is there a fix?
geposted Fri 19 Dec 08 @ 3:46 am
you got all of your updates...
geposted Fri 19 Dec 08 @ 8:15 am
Yes, as far as I know, when I registered the software a week ago I downloaded the latest version of the software off the site.
geposted Fri 19 Dec 08 @ 8:40 am
downloaded off hercules and vdj? the cd is not the latest version you have to d/l from here. would also check mix lab is updated to 5.-- not sure if it is
geposted Fri 19 Dec 08 @ 8:49 am
If you have Safemode or Overclock checked in the Performance settings then uncheck them. Also make sure the Latency in Performance is at Auto.
geposted Fri 19 Dec 08 @ 9:46 am
