It's very simple to add it :)
geposted Sat 11 Apr 09 @ 7:57 am
i'd like a pitch bend too, if it is possible..;-)
geposted Sat 11 Apr 09 @ 6:04 pm
Will it be done? Just asking.
geposted Tue 14 Apr 09 @ 3:52 pm
i want it too :p i'm really missing it
geposted Wed 22 Apr 09 @ 2:31 pm
missing the pitch bend?
geposted Wed 22 Apr 09 @ 9:17 pm
no i am missing the shift knob which you allows to adjust the position of the loop.
geposted Tue 28 Apr 09 @ 2:21 pm
oh k...
geposted Tue 28 Apr 09 @ 4:18 pm
i really enjoy this skin..thanks to the designer
one questions is there a verison with the graph sliding vertical instead of horizontal? I thought Scratch follow that way...just to make it look more real or is that against the regs?
Just wondering
oh yeah is there a skin for Stration c324 cdr?
Just wondering
geposted Wed 06 May 09 @ 6:50 am
VDJ 5 doesn't support vertical wave.
geposted Wed 06 May 09 @ 7:02 am
i hate verticals, one of the reasons i hate serato..
geposted Wed 06 May 09 @ 8:36 am
oh ok...didnt know that...
never the less its fun when folks look and be like thats that new scratch joint I read on that...and I look at them like WTF are you talking about...lol
geposted Wed 06 May 09 @ 9:18 am
[MESSAGE MOVED]
@SSLover
Could you update your skin if you have spare time because I'm sure a lot of users will want a fixed version. Especially, to fix the sampler.
The trial version of VirtualDJ v6.0 is now available.
Thank you in advance,
DJ CEL
VirtualDJ Team
@SSLover
DJ CEL
VirtualDJ Team
geposted Wed 03 Jun 09 @ 7:48 pm
this is a question for the ssllover creator of the vinyl scratch skin, FIRST, this has to be 1 of the Best skins i have seen, THANK YOU!! ok could you please make a day time skin, that would work with 5.2?? I ask for a 5.2 cause i dont plan on updating (or i cant anyway cause Numark has not released it yet) That would just make my day (as well as others i'm sure)hehe. For me this is the best skin i have used because of the ease of use. I love to use effects and you have given 6 slots for effects on both decks!! This is great because i use turntables and its a pain to have to go into the effects folder and rush to find the effect that i want. Having the Key right there is great cause i forget which Key the song is in, now that wont happen anymore. Also the BYPASS Button saves me time on the setup and when im spinnin a gig cause i scratch. I can scratch a time code but its nothing like a real record. Dont know how it works but it does!! I could keep going on. A daytime skin would be sic, as its summer time i do a lot of outdoor events. So please could you email me and see if we cant work out a deal??
Thanks for your time and a great peice of work!!
STAY FRESH & KEEP IT FUNKY!!
P.S.
L2 i havent forgot about you Thanks for the frame work!!!
MUCH RESPECT!!
P.S.
MUCH RESPECT!!
geposted Thu 04 Jun 09 @ 10:28 pm
OK, can some one point me in the right dicertion as far as "HOW TO MAKE A DAYTIME SKIN"?? Or "how to change an existing skin to a daytime skin"??
Thanks for your time and help!!
geposted Fri 05 Jun 09 @ 7:32 pm
the quickest was to make a day skin is open the zip file and then in some photo/graphic editor software make a "invert the colors"
most everything will be ok but somethings might be better if developed further. example since the skin would be primarily white why not then change all the text to black for best viewing. Things like that. But yes an invert of the BMP file would do the trick.
geposted Fri 05 Jun 09 @ 8:03 pm
Hello everybody,
I'm working on the new version using VDJscript. Almost all the code is now translated.
I will add some options too as I have new ideas :-)
I hope to release a first version soon.
@djcel
I fixed the sampler area.
@djcel
geposted Thu 11 Jun 09 @ 3:39 pm
A first beta version of my skin for VirtualDJ 6.0.1 is now available: Dark (1280x800)_v10_beta_VDJ6
You can download the old package including this new skin here:
https://virtualdj.com/addons/4369/Vinyl_Scratch_variations.html
More colors and size will come for the final version of course.
Feel free to add comments.
New features:
* Totally rewritten in VDJscript
* New scratchwave
* New SongPos in circle
* New pannels for Sound Effects : Main / Slots / DJC buttons
* New options in the options menu of the skin
* New helpfull Tooltips
* Now save the Key / Clock display
* Play / Cue /Stop can be switched between Numark and Pioneer mode
* Slow seek is now Pitch Bend
* Two speeds for pitch reset
* Master/Deck Volume
* Added Headphones gain on Headphones pannel
* Clear search button
* Fixed Sampler
New features:
* New scratchwave
* Fixed Sampler
geposted Sun 14 Jun 09 @ 3:14 pm
Very cool skin.
geposted Mon 15 Jun 09 @ 2:20 am
Pls update 1024x768 too, thx.
geposted Mon 15 Jun 09 @ 4:35 am
@sslover
are you gonna include the vertical scratch wave PLUS the horizontal wave line in the final version? (maybe optionable)
that would look awesome :)
anyways its the best skin for vdj...love it!!
geposted Mon 15 Jun 09 @ 2:17 pm
