Forum: VirtualDJ Skins
Topic: Vinyl Scratch v6.0 - Page: 7
hey dj fandos where is the radar vinyl skin?
farhanashraf, music 234, I have found the solution to the problem that you where having as I had the same issue. This only applies in version 11, you have to click on the words sound effect and it will change to DJC which will work great with RMX. Hope it works for you!
click on what?
oh k and it changes to the word DJC?
that's correct. The DJC will be the ones that the RMX controller will use as the 6 buttons that can be programmed
thanx man, I'll try it ;-P
Great radar skin but where do you download it?
thanks man, thats awesome, what is the other setup used for, just for clicking on the skin?
The other ones i guess you can use them as shortcuts to the FX that you can use with your mouse or keyboard shortcut. So in total if you use your mouse you can 12 fx per channel that you can access quickly
thanks!
Hello Dear DJ Fandos
Fantastic job
but could you also put the lenght of the song, and the rest time of the song in the Jogwhell. First line upstairs, second line downstairs..
Look at the skin https://virtualdj.com/addons/1275/Vinyl_Scratch.html.
Thanks, and I`ll be happy when you will do this.
Greetings
Chris
how can i get this skin?
anyone?
Pay for a Licenced Virtual Dj pro and you will be able to access the WORLD!!!!...he,he
actually, the skins been removed so you won't find it on here.
Right!...so...happy hunting...imao
damn it! ;-P
actually i take that back, i saw this very skin still available. for some reason it was in the video skins. or something.
nope...he pass it on to someone ,who modified it further so it got accepted, but...no more "SL" type skins will be allowed...
new vercion 2.o
99%
