no problem :-)
geposted Mon 29 Jun 09 @ 4:54 pm
Djlilfasay wrote :
Listen2, you have big problem in your skin:
The vertical scratch waves dont match the sound actually.
I can scratch, before im actually visually at the beat.
I´ve fixed this in my version. take a look. set a cue point at a kick or snare with a diffrent skin switch over to yours and scratch youll notice that the visual scratch wave doesnt match.
You just need to change the height to fix it!
your right the exact position of the scratch waves were a little bit off. It was not the position it was the middle line not being drawn correctly. I have corrected the bug ... i was only off really like 8 pixels so i would not consider it a big problem but thanks for pointing it out.
http://www.virtualdj.com/addons/8388/Vinyl_Scratch_Vert.html
Your mod is fine, i think its taking its own "personality" as i stated i was trying to reproduce the functions and look of serato. Your's is going beyond that and becoming something different, but that is the beauty of skinning. You make what you like.
If i understood you correctly you releasing 2 different versions? IS that because of the different waves? you could easily just put them ina pannel and only have one skin. Check out the pannel coding.
geposted Mon 29 Jun 09 @ 7:47 pm
great to hear you like it and you found the bug i tried to explain :-)
yes i was going to release 2 skins, ill look into tutorials about panel coding, however these are my first skin edits i post here :-) so im very new to this.
geposted Tue 30 Jun 09 @ 12:43 am
I forgot to mention that i only use a texteditor to edit the skin.soon ill be able to donate and then i can use the skin creator :-)
geposted Tue 30 Jun 09 @ 6:24 am
ill release both in one zip thats the easiest way before ill go onto my vacation today :-)
update on the scratch wave lines
geposted Thu 02 Jul 09 @ 12:48 am
how soon can we see both of lilfasay's skins on the downloads?
great job listen2,fandos and lilfasay....thank you
geposted Fri 03 Jul 09 @ 3:15 pm
This is by far the most impressive skin! Thanks to all for your hard work.
Syberman
Syberman
geposted Sat 04 Jul 09 @ 8:50 am
vinyl radar...............
geposted Sun 05 Jul 09 @ 4:25 pm
geposted Sun 05 Jul 09 @ 10:55 pm
Fandos thats badass, Need it 1280X1024 and minus all the TCV stuff if u could.
geposted Mon 06 Jul 09 @ 3:00 am
Yup, looks real nice... +1
geposted Mon 06 Jul 09 @ 8:01 am
completed and uploaded
geposted Mon 06 Jul 09 @ 10:39 am
Is there anyway someone can make the waves in the middle window transpartent to one another? Any help is alway aprreciated.
Syberman
Syberman
geposted Mon 06 Jul 09 @ 11:15 am
After all these new skins, even though the skins you created are very good too, we are waiting for SSLover original skin (in my case I prefer RED-BLUE skin to be in agreement with the Original style of VDJ software).
geposted Mon 13 Jul 09 @ 2:10 am
so i just got the vdj 6.0 and dled the latest version of the vinyl scratch skin (http://www.virtualdj.com/addons/4369/Vinyl_Scratch_variations.html) to run it with my rmx which i hook it up with my ttx to run tcvs, basically a dvs suystem with my rmx as the soundcard,
so i load up the fx i want on the 6 slots on the skin and then try to use them thru the 6 button on the rmx and it doesnt work. it seems that it is stuck on the default loop in, loop out fx,
how do i change em? i know there some driver/effect where they would let you to save specific fx patterns on the slots, it came up as RMX under the effects tab, i dont see it under the effects page here, how can i fix this?
geposted Tue 03 Nov 09 @ 5:58 pm
@ Mr Fandos
The skins looks awesome im amazed right now :p
Good job
DJ ALEX
Good job
DJ ALEX
geposted Sat 07 Nov 09 @ 7:59 am
may name is dung! 18 agd
geposted Sat 07 Nov 09 @ 8:23 am
what's the name of the skin with radar . i can't find it in the skins section.
geposted Sat 07 Nov 09 @ 1:11 pm
@ DJ azen:
...that is a good question. I also :(
Music234
Music234
geposted Mon 09 Nov 09 @ 10:51 am
my vercion
geposted Sun 15 Nov 09 @ 9:57 pm
