Using 5.2.1 on the clubs cpu...
It seems that I'm starting to have a problem of scan information for files mysteriously missing. I'm rescanning a batch of songs that were previously scanned. I recursed my main folder and then sorted by bpm and scrolled to the bottom to find a bunch of files missing its bpm and length.
What could be causing this information to keep vanishing? Thursday it was 2 files tonight it was a bunch...probably around 30 or so.
SOmething else I'm noticing..a lot of my artist information is missing and the file information is all under the "title" section. I have everything in browser tab disabled.
Well geeze louise...its more like a hundred files or so are messed up. is there some tool that will fix it? I need title under title and artist under title NOT artist-title (mix) all under title.
Man all these qerks that just started happening is already getting old.
Thanks for helping a legit PRO user!
geposted Fri 19 Dec 08 @ 10:01 pm
