Topic: waveforms are glitchy
Hi all,
Just re-installed my system and everything is working great, except for the glitchy wafevorms at the top of the screen. I had this problem about a year ago when I did a re-install and can't remember for the life of me what I did to fix it. I searched the forums with no luck either.
I know my Video card says it's 256 MB, but actually shares half of that with RAM. I think I somehow disabled this sharing and that fixed my problem last time.
Any suggestions on how/where to do this?
Dell Inspiron E1505
2GHz Core 2 Duo
2GB RAM
ATI Mobility RAdeon X1400
Thanks!
geposted Sat 20 Dec 08 @ 9:56 am
What soundcard are you using? I've noticed some creative cards do this (but only when running in ASIO mode).
I got the same laptop you have, try checking overclocking it works for me.
@ sbdj: I'm using the Hercules MKII as my ASIO sound card
@djpr1: That sounds familiar. Where can I find the option of checking the overclock?
Thanks!
go to performance it is under your latency settings.
Here for a clear view:
I'm pretty sure I have overclock checked, but I can't remember for sure. I'll try playing with some settings when I get home and let y'all know how it goes.
Thanks for the help so far...
Try turning Safe Mode off if it's on.
