ok im using this sound recorder to get samples off of movies..like certain words are said in a movie i like so i wanna use it as a sample in mixxes..so im using the trial version of this thing callled HI Q RECORDER...have u guyzz ever heard of it??if so is it good? Or do u guyzz know any other software recordings that are better?? i wanna buy the full version of this software but i want to know if its good or if there are better ones out there....oh it can record sounds up 320 KPS!!!
geposted Sat 20 Dec 08 @ 11:03 am
anybody i know itz vacation thou...
geposted Mon 22 Dec 08 @ 2:58 pm
Never used it but if you are recording samples and playing them just as they are, I'd say any recorder would do. Unless you plan on tweaking the samples, go with it if you've become comfy with their trial version.
geposted Mon 22 Dec 08 @ 3:13 pm
