it won't let me play it. It says the dynamic link libary DINPUT8.dll could not be found in the path
C:\Program files\VirtualDJ;.;C:\WINNT\System32;C:\WINNT\system;C:\WINNT;C;\WINNT\system32
;C:\WINNT;C:\WINNT\System32\Wbem what do i do when this happens
Jason
Jason
geposted Sun 13 Feb 05 @ 5:29 pm
Did you install DirectX from Microsoft before using Virtual DJ?
geposted Sun 13 Feb 05 @ 6:26 pm
that might indicate that you have disconnected something that you were previously using with VDJ. I got that whenever I start VDJ without first plugging in my XP-10.
geposted Mon 14 Feb 05 @ 3:57 pm
I got the same message DINPUT8.dll missing. Please clarify the solution. Do I have to re-download direct X from microsoft?
geposted Sun 06 Mar 05 @ 9:48 pm
Yes, the DINPUT8.dll is a .dll from DirectX
Btw, Virtual DJ use some Direct X .dll to run, so be sure you have the last version of Direct X installed
Coyote
Coyote
geposted Sun 06 Mar 05 @ 10:14 pm
Check to be sure that all devices that VDJ was using when it was last shut down are properly attached.
geposted Mon 07 Mar 05 @ 5:11 pm
