Hello all, I am still having LOTS of trouble with my pitch bouncing around and not being stable. Can someone with a stable TCV and Maya44 setup tell me the setting that you are using? Any help is always appreciated.
Thanks
Syberman
Thanks
Syberman
geposted Mon 22 Dec 08 @ 2:30 pm
Did you try the "Pitch Sensitivity" option in the Timecode config mate,
Default setting is 500, but I've set mine to 900, and it's stopped the BPM fluctuating.
geposted Mon 22 Dec 08 @ 2:50 pm
Jimmy, I've tried everything under the sun. The damm thing is jumping like it has ants in the pants!
Syberman
Syberman
geposted Mon 22 Dec 08 @ 3:31 pm
Got it fixed, I have it set to 500, 1200. Thanks DJPR1 for helping me out!
Syberman
Syberman
geposted Tue 23 Dec 08 @ 10:02 am
D'OH, I should of told you to keep increasing it, till the BPM holds steady.
Nevermind al teast your sorted now mate :)
geposted Tue 23 Dec 08 @ 10:10 am
No problem Jimmy, the main thing is that it's not jumping around! Thank you as always.
Syberman
Syberman
geposted Tue 23 Dec 08 @ 2:00 pm
Syberman
Syberman
No Sweat Bro.............
geposted Tue 23 Dec 08 @ 10:28 pm
