Hello everyone..Newb here..
This is my first post and I need help in choosing a controller for VDJ pro to run off of my mackbook.. I already have a mixer but I'm torn between these 2 choices..
1) Hercules RMX
or
2) numark Dmc2 with a maya 44 sound card.
I was thinking of going with choice 1 since everything is intergrated in one unit but also was thinking about #2 also, so if I decide to change my setup, I already have a sound card and don't have to worry..
Any recomendations would be greatly appreciated..
Thanks in advanced and happy holidays..
1) Hercules RMX
or
geposted Tue 23 Dec 08 @ 2:12 pm
Hi and welcome, can only give advice on the RMX as i haven't used the DMC2, it's a mid range unit and doe's what it says on the box basically, good thing is it is becoming quite a popular controller here on the forums so any problems you may have with settings etc you know there will always be help not to far away.
geposted Tue 23 Dec 08 @ 2:33 pm
same as tayla ive only use the rmx and find it brill especially after the forum and the help.to me from those choices it would be the rmx mate
geposted Tue 23 Dec 08 @ 2:43 pm
