O.k. I have a song loaded and playing on Deck 1. I have a song loaded on deck 2. Now, I play deck 2 and it plays for about 7-15 seconds and then it goes back to the very beginning of the song! It does this on both decks, 1 & 2. Any fix? Hope so. As always, any help is always appreciated.
Syberman
Syberman
geposted Wed 24 Dec 08 @ 11:29 am
Anyone?
Syberman
Syberman
geposted Thu 25 Dec 08 @ 11:45 am
sounds like you have hit a shortcut key for loop... try and disable.
geposted Thu 25 Dec 08 @ 6:19 pm
No, it's not like a loop Tayla. I start a song and it plays for 7-15 sec. and it goes back to the very beginning and then it plays all the way thru. It happens on both decks, not only the one.
Syberman
Syberman
geposted Thu 25 Dec 08 @ 6:30 pm
"and then it plays all the way thru. It happens on both decks, not only the one." you never mentioned that before... lol
well it certainly sounds like a short cut key has been activated, if you use them disable shortcuts in config and see if that is the problem, if not sorry i couldn't help.
geposted Thu 25 Dec 08 @ 6:52 pm
take it that was the problem then....
geposted Fri 26 Dec 08 @ 10:14 am
