Anyone else using VJ Ripper.
I would like to know the best setting to use.
geposted Wed 24 Dec 08 @ 10:36 pm
So it seems I am the only person using this software or has everyone been to busy getting drunk over xmas?
http://www.clubdjpro.com/vjripper.php
geposted Fri 26 Dec 08 @ 7:50 am
I've been using it for about 2 years.
I have it set on MPEG2 - dvd quality.
Works perfectly fine. It takes a very long time to ripp an entire DVD if left on it own. However - the results are as good as using the RippDVD program that comes with VDJ.
geposted Fri 26 Dec 08 @ 9:26 am
I don't use it but I did check it out, from what I see ( http://www.imtoo.com/dvd-ripper.html ) which is what I use has the same features at 1/2 the cost. :0)
geposted Fri 26 Dec 08 @ 9:59 am
Does the ripper that comes with VDJ not work for all DVD's that you have? I'm trying to rip dvd's from tophitsusa.com, and about every progra is giving me problems or is not the quality I like.
I've downloaded the trial version of VJripper, but I can't seem to get the settings right. I don't really like the quality. I wish it would just rip to .vob like all of my other videos.
What are your thoughts?
Chris
Chris
geposted Tue 30 Dec 08 @ 9:55 am
