Some of the VDJ plugs don't work. Last night a plug jammed my computer and I had to reboot. Embarrasing. Now I try to delete the audio plugin and I can not figure out how.
My search got me to one answer which was "go to the folder and delete the file". Not helpfull. What folder, what file etc.
Beatbox locked up my computer and I want it out. How? Please be specific. Thanks.
geposted Wed 24 Dec 08 @ 11:06 pm
Open windows explorer.
Browse to your "My Documents" (XP) or "Documents" (Vista) Folder.
In here go into the "VirtualDJ" folder.
Then Plugins.
Then SoundEffect.
Select the plugin you wish to delete, then press the delete key on the keyboard.
Click OK to confirm deletion.
Be aware that BeatBox was designed for VirtualDJ 3.4.
Then Plugins.
Then SoundEffect.
geposted Wed 24 Dec 08 @ 11:28 pm
That's it. Thank you!
geposted Thu 25 Dec 08 @ 2:57 pm
