Hey all,
I searched and searched, but cannot find a solution to my problem.
Every time I open VirtualDJ, I have to re-analyze all of my songs BPMs, and this takes way too long.
Is there a way to just scan through the songs one time, and then save the BPMs for future use?
Thanks
Thanks
geposted Wed 24 Dec 08 @ 11:59 pm
Register your serial in your profile .... http://www.virtualdj.com/users/edit.html
-- Your issue is a permissions issue ---
Go to the /Documents/ folder and Control+Click (right click) on the VirtualDJ folder
Choose the Get Info menu choice
Then in the bottom right corner of the Get Info dialog you need to click on the pad-lock and unlock it (will prompt you for you user password)
Then just above that to the left is the Permissions list. Make sure your user account has Read/Write permissions set.
Just below the Permissions box there is a button with a gear graphic on it - click that and choose the 'apply to all included' items
Once changed, close the box to Apply the changes.
geposted Thu 25 Dec 08 @ 10:20 am
Problem fixed!
Thanks a bunch, and happy holidays!
geposted Thu 25 Dec 08 @ 3:08 pm
And pls register ur serial in ur proflie n updates to the recent version. Thanks;)
geposted Thu 25 Dec 08 @ 3:50 pm
