I MISTAKENLY PRESS THE ASIO CARD WHICH HAS COURSE MY NOT PLAYING,BECAUSE I ONLY USE THE HEADPHONE TO MY MIXER,WHAT CAN I DO TO RESTORE IT ? I NEED THE SIMPLE SOUND.
geposted Thu 25 Dec 08 @ 4:32 pm
Just select the simple settings in the "sound set-up" tab in the configuration tab of vdj. Also, you can restore all defult settings to VDJ by selecting it in the "info" area of "configuration". It won't effect your playlists, favorites, etc.
I hope I understand you and this helps!
Chris Kelley
Chris Kelley
geposted Tue 30 Dec 08 @ 6:54 pm
